an error occurred trying to load the assembly
    I am using a .net constructor node and I recieve the following error when i use browse and select a .dll.
 "an error occurred trying to load the assembly"
The .dll is in the same folder as the LV project.
The .dll targets .net framework 2.0
I can link to/use the .dll from a simple command line project, the .dll make public one simple class and a constructor for its.
Is there any way to get more information out of labview as to what the problem is?
baldrik.
(5,485 Views)
(5,465 Views)
#include "stdafx.h"
using namespace System;
extern "C" {
namespace clrtest {
    public ref class testClass
    public:
         testClass()
         int foo(void)
            return(42);
Compiling the above minimal c++ code  into a clr dll gives the same cryptic
"an error occurred trying to load the assembly" when the .net constructor node tries to load it.
I am far from a .net expert or a c++ one for that matter.
Anyone know what is missing from the above code?
Ultimatley I want to write a wrapper for cyusb.lib a static (c++) library for the FX2 USB chip from cypress exposing some of its functionality to labview.
Cheers
baldrik
(5,452 Views)
I am having this same problem, except it works for one administrator login, but not another one.
LV2012 SP1 on win7
thanks,
Paul
(4,640 Views)
