an error occurred while attempting to read from the onboard devices of ni myRio
Hey guys,
I´m getting started with the myRIO-1900 and when I launch the "Getting Started Wizard" it´s telling me that the myRIO is found and in the next step it tells me that I have to rename the myRIO to reboot it. Then it says that an error occurred attempting to read from the myRIO´s onboard devices.
When I skip this I can open a new project but if im trying to run it, there´s is happening nothing. The myRIO does not respond.
When I cancel this, another window is opened but it don´t know what to do with it.
So please help to get the myRIO running.
ps: i share this problem from other's post because i faced the same problem also but there is no solution. Please help ! Thanks !
(3,393 Views)
Hey guys,
error 3.pngSo please help to get the myRIO running.
ps: i share this problem from others post because i face the same problem also but there is no solution there. Please help ! Thanks !
(3,393 Views)
Can anyone one help me please ? i stuck at here for a long time already 😞
(3,354 Views)
install system configuration
(2,503 Views)
