analog and digital - stop
hi,
i have one problem..
i attached the vi where i have a question..
i want when the digital stop to stop and the analog..
the analog i want to acquire a measurements continuously until the digital stop..
i try many combinations.. but they do nothing..
pls help me..
thank you very much!!
andrikos
Message Edited by andrikoscy on 04-17-2008 12:49 PM
Message Edited by andrikoscy on 04-17-2008 12:50 PM
Message 1 of 11
(3,397 Views)
Hi andrikos,
i´m sorry, but i don´t understand what you try to do. Can you please explain it again??
Mike
Message 2 of 11
(3,379 Views)
hi,
i want the 2 program start to executes at the same time and stop at the same time!!!
but!,
the digital program stop when it will measured whole the samples
the analog must measures analog measurements continuously until the digital will stop! then and the analog must stop.
how can i do this?
thank you very much for your interest!
andrikos
Message 3 of 11
(3,374 Views)
Hi andrikoscy,
if both processes shall run at the same time, you can´t connect them with a wire. I think you need 2 while loops to do what you want. See the attached example.
Hope this helps.
Mike
Message 4 of 11
(3,351 Views)
Mike,
can you send me a picture of the example?
because, i can't read it...
i have Labview 7.1
andrikos
Message 5 of 11
(3,344 Views)
Hi andrikos,
here is the picture.
Mike
Message 6 of 11
(3,342 Views)
hi Mike,
your idea is nice! it works!
i have another one problem now..
the analog don"t plot the measurements or i can;t  get the measurements into an array..
do you know why i have this problem?
pls help me..
thank you very much for your time and interest!
andrikos
Message Edited by andrikoscy on 04-18-2008 06:30 AM
Message 7 of 11
(3,324 Views)
Hi andrikos,
there are different ways. You can add a chart to see all values, you can store your values in an "dbl" array or you append the waveform to an existing one. See the attached picture.
Mike
Message 8 of 11
(3,319 Views)
hi Mike,
i attach a picture of the vi..
i add a chart which called measurement..
and when the vi executed.. i don't see anething at the chart.. nothing!
why?
andrikos
Message 9 of 11
(3,307 Views)
the picture...
Message 10 of 11
(3,304 Views)
