analog input doesn't work in executable
Using a PXI-6254 module to read 14 analog inputs.  Analog inputs work fine in editor mode.  However, when I build an executable, the last 2 inputs do not  read correctly.
(2,778 Views)
Hi Roese,
can you show your vi? How do you read the data? Are you using a predefined task from MAX? Maybe there are different descriptions for your development enviroment and your executable.
Mike
(2,745 Views)
