07-17-2014 03:51 AM
Hi
I am new to labview, i am stuck in a task .
My task is to measure edge to edge time periods of 10 pulses which will be analog input e.g initially 3.3 v is there then due to some block in sensor it is dropped to zero .& again if that blocking we took out it again come to 3.3v , so ineed timing of two high edges happened for 10 pulses. .
and if it is with in range then add to a variable else other variable .
Can anybody help me in this to create Block Diagram of the same
I need to capture time period for the following Pic .
thanks & regards
Nitin aggarwal
07-18-2014 11:08 AM
How are you measuring the data? DAQ or will you be reading the waveform from the scope you got the picture from?
Mike...
07-20-2014 10:55 PM
Morning Mike
waveform I attached Was just for reference to show what i need to capture Through labview.
basically I will use labview for this.
Thanks & regards
Nitin Aggarwal
07-20-2014 11:17 PM
07-20-2014 11:33 PM
Hi
I am using a Phototdetector In my project
This photodetector output i want to monitor using labview.
If i am getting a pulse of <20ms Duration then c1 ++.
else >20 then c2++.
This logic i want to create in labview How to Do this ?
07-21-2014 12:08 AM
07-21-2014 01:46 AM
Photodetector output i will probe to DAQ card NI-6341 .
c1 & c2 Will be the counters . No i have not taken any tutorials yet . can you please send me the links for the same .
07-21-2014 06:20 AM
Nitin_110051 wrote:No i have not taken any tutorials yet . can you please send me the links for the same .
Also be sure to go through the examples that are installed with LabVIEW. They can be found by going to Help->Find Exampls.
07-21-2014 11:42 AM
You can do this with counters, or a normal digital in with post processing. Create a finite, or continuous task where you read the signals for so long, then count the edges likely with an XOR or a built in function under the signal processing palette.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
