analog inputs and digital outputs usb 6009
@surferEE wrote:
I created the channel now I am not getting any readings on AI0-2.  I have attached the VI.  Thank you for your help Apok!
try this one...
Spoiler
Message 11 of 15
(2,130 Views)
Your code produced an error as follows:
Error -200463 occurred at read write mod.vi
Possible reason(s):
Specified read or write operation failed, because the number of lines in the data for a channel does not match the number of lines in the channel.
If you are using the Digital Waveform datatype, make sure the number of lines in the digital waveform matches the number of lines in the channel. If you are using boolean data, make sure the array dimension for lines in the data matches the number of lines in the channel.
Number of Lines in Channel: 1
Number of Lines in Data: 8
Task Name: _unnamedTask<37>
I updated my code to reflect what you suggested with constants instead of controls, see attached.
I surf therefore I am....
Message 12 of 15
(2,127 Views)
Accepted by topic author surferEE
replace your graph with a waveform chart and connect the error line...
Spoiler
Message 13 of 15
(2,123 Views)
Success!  It works, now I need to toggle the digital output while the analog input is still being sampled.  I will post my test vi again once I have implemented the code.  Thank you.
Message 14 of 15
(2,118 Views)
Even more success!  Super stoked!  Attached is my solution to toggle the digital outputs using a nexted case statement.
Message 15 of 15
(2,111 Views)
