analog out problem
I am generating pulses ans sending them through the analog outs. I have the outs connected to the oscilloscope. When i run my prog. both the analog out channels shift up by 5v. When i stop the prog it remains in the shifted 5V. Now i goto the Measurements and Automation software and say test on either one of the analog out and it falls back to zero. But when i run the prog again i find the output shifted by 5V. Can anyone tell me why its happening this way? Thanks!
(2,790 Views)
You could upload the vi in question so we can see what's up.
Sounds like you aren't putting a "reset" segment into your program, such as a frame at the end that sets the AO's to 0V.
Run vi->Set AO to 5V->Do stuff->Set AO to 0V->Shutdown vi.
MAX well reset the AOs when it opens up, so you need to do the same within your program.
2006 Ultimate LabVIEW G-eek.
(2,790 Views)
