analog output generation
Anyone can help me!.....this is  bharat H
i am generating analog output signal...in that everything working fine but daq write function throwing error msg ..i am fresher for labview i am not understaing what this error msg. For generating analog output signal  i given parameters below
max value:5
min value:0
output terminal configuration RSE
sample rate:100s
signal frequency :10Hz
amplitude: 2
using 6009 usb
(3,037 Views)
Accepted by topic author NI0022818
Hi bharat,
the error message is pretty clear!
You try to output a value out of supported value range…
(3,026 Views)
i am not getting what you are saying ..please tell me what i am doing wrong.
(2,994 Views)
Hi NI,
your device supports an output range of 0V to 5V, but still you try to output a value of -1.17V.
Do you see the problem now?
(2,986 Views)
hmm k sir that's got it...But i configured in front panel min value:0 and max value:+5. then also i am getting same error msg. i given signal frequency 10 and sample rate is 100. when i changed sample rate as a 20 insted of 100 then i will not get error but data its not getting.
(2,934 Views)
