Using all of your wonderful suggestions and tips, the attached file is what I came out with. Without attaching any equipment to the device (generators, meters), it seems to work excellent. You hit the first stop button (simulating the error ending the input loop) and the output loop will run for the Target Time (in seconds) before returning to the input loop. So, everything works fabulous...
Until I add a sine, square or dc voltage (I was trying everything) to the input. For one, hitting stop will not go to the ouput voltage. For two, even if my input voltage surpasses the min/max channel settings, all it does is clip the signal, instead of triggering an error to end the loop.
If I don't put an input in, and hit stop (to check the output loop), it does output my desired voltage - only it doesn't drop the voltage back to zero,, but continues to output the same voltage even after we are reading an input again. I only want a voltage to be output when we are in the ouput loop (thus simulating a pulse of variable length).
Could you take a look at my vi, and help me get it to work from here?
Thanks so much!
