analog trigger 6071
A simple question for you:
when I choise analog for the trigger in PCI 6071 and I use PFI0 channel , where I must connect the minus of the signal?
(2,669 Views)
Greetings delpitik,
Thanks for contacting National Instruments. The appropriate pin for your connection would be AI GND (pin 76). This information can be found by right clicking on your device in MAX and selecting Device Pinouts. Also, when you create a new DAQmx task in MAX, you can also specify the type of analog trigger. (i.e. edge, window, etc)
Thanks and good luck!
Jordan Randall
National Instruments Italy
(2,654 Views)
