analog trigger 6225
I have bought 6225 daq and now I´m getting PCB from where I need to measure signals and run other test. Problem is that in my test software I need to trigger signals and that signals are connected to ai20 and ai52. Whole testsystem design is done elsewhere and they haven´t seen that 6225 boards do not include analog in triggering, or do they??
I´m in quite a hurry and need to get system up and running soon. Can I somehow do this analog in triggering in a different way?
Signal is 0V in the beginning and when it rises above 2 Volts I need to acquire 1000 samples at "x" scan rate?
Can you please help me, I´m just a beginner with Labview so this can be trivial to all of you.
Thanx, PEJ
(2,627 Views)
I am sorry but NI 6225 board does not support analog triggering. 625x and 628x boards do support analog triggering. So I recommend these boards as a replacement for your application.
Vesa K
(2,620 Views)
