 charles0601
			charles0601
			01-13-2010 03:00 AM
I need send a external trigger to RFSA. The function gen is used to send analog triggering to RFSA. The problem is that i
can't find driver for analog trigger in RFSA. Is there any way to resolve? Thank you.
Charles
 GovBob
			GovBob
			01-13-2010 11:15 AM
Charles,
What version of LabVIEW are you using and what hardware are you using? If you open LabVIEW and look in the example finder and search for RFSA you should find and example VI called "NI 5660 Trigger IQ.vi". Will this work for you?
Hope this helps.
