analyze video with edge detection
hello..
i'm new to LabVIEW 7.1 and vision assistant 7.1. In my assignment, i needed to analyze a traffic video. The method is by edge detection. But i have no idea at all how to do it. So, please help me. I need to pass up this assignment before beginning of September. How i going to start this analysis??What tutorial i need to study?What step need to do to analyze the video with edge detection?Is it necesary to do use Vision Assistant together?
thanks for help!!!
(3,239 Views)
Hi Chin,
I suggest opening example scripts and images, trying to figure out how the examples work, then replicating the methods on the sample images.  Vision Assistant is built to be a simple method for writing complex LabVIEW code, so it will be a great place for you to start.  Also, try searching the forums for example scripts, and see how other users write their code.
Good luck!
Maclean G.
Applications Engineering
(3,212 Views)
ok...i will try my very best to study the exmaple....thank you very much.
(3,194 Views)
Hi Chin,
Here is a link to a really helpful website all about edge detection in our software:
http://zone.ni.com/devzone/cda/tut/p/id/2752
The link below shows how to write LabVIEW code to do an edge strength profile:
http://digital.ni.com/public.nsf/allkb/34E524B23E9B88C28625711D000E2027
Below is a link to a tutorial on general image processing:
http://zone.ni.com/devzone/cda/tut/p/id/3470
I hope these point you in the right direction.
Maclean G.
(3,173 Views)
