and fra stringhe
Buongiorno a tutti!
Volevo chiedere se c'e' un modo di fare un AND fra stringhe, poiche' io vorrei che il programma entri in un ciclo while solo quando sono verificate due condizioni contemporaneamente.
Grazie
Giulia
(3,213 Views)
Ciao Giulia
If I understand you right, you might be looking for a "string compare" .
Asking questions in a bad english is always better than a foreign language.
There should be an italien user group ?
Gabi
7.1 -- 2013
CLA
(3,203 Views)
I am really sorry, I thought it was a forum in italian (stupid auto-google translation 🙂 ). I can explain the problem in english: I need to do an AND between two errors, because I want the creation of a file only when both two errors are 0. Is it possible?
(3,201 Views)
Accepted by topic author Giulia_De_Luca
You are looking for the status item of the ERROR cluster.
The status (or what ever it is called in the Italian version) is a boolean that you can AND.
BTW: Your English seems more impeccable than mine (sono tedesca)
Gabi
7.1 -- 2013
CLA
(3,193 Views)
I have (more al less) no problem with english, but a lot of problem with the automatic translations! I never understand what is the original language. 🙂 Thank you for the answer!
Giulia
(3,182 Views)
