angles between lines
It is a very elegant use of the complex math function but how can it be scaled for n > 2 dimension vector space? Using the Dot Products function ( and modifying the points generation FOR loop) the following code is valid for any n >= 2 value.
Ben64
Note: Where did the "quote" button went?
Message 11 of 16
(3,301 Views)
It now has the quote symbol on it.  "           Right after bullet list, and numbered list.
Message 12 of 16
(3,290 Views)
But it's missing on mobile 😞
Message 13 of 16
(3,280 Views)
The quote button is there but is not working with a french installation of IE11.
Ben64
Message 14 of 16
(3,275 Views)
Cosine rule?
I'm not sure if it's easier though. Probably a bit faster, although you never know until you benchmark.
Message 15 of 16
(3,240 Views)
wiebe@CARYA wrote:
Cosine rule?
Yes, that's basically a cleaner version of this old code above..
Message 16 of 16
(3,213 Views)
