animated dots
Hello Everyone!
I would like to make my project a bit more fancy, so I would like to make a little animation on the status string indicator.
Please see the attached subVI, I have also attached a main calling VI, so you can see how I want to use this. I would like to ask your opinion about my approach. Can I make it better? Also, I do not like the coercing red dot on the input of the subVI.
Thanks very much for advice!
Best Regards,
(3,153 Views)
Accepted by topic author Blokk
Firstly to remove coercion dot.
Create a string reference control,copy and replace with ctl refnum in subvi and remove 'to variant' vi.
Second.. Use classic controls.
Bijay
(3,143 Views)
Thanks, no more coercing dot 🙂
I guess using classic controls in subVIs instead of modern controls make better downward compatibility? Is this the reason?
(3,138 Views)
