animation
Can someone show me how to implement an animated Valve opening and closing.
(3,568 Views)
Hi Russellg,
you can use a picture control to animate it. The animation can be read from a gif file.
http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=435202#M435202
Mike
Message Edited by MikeS81 on 02-26-2010 04:02 PM
(3,566 Views)
Hello Russell, Were you able to get that working?
(3,524 Views)
No Anna,
Not at this point .
All I need is a way of displaying the opening and closing of a valve.
I've looked at link, but did not quite follow it.
If there is an example VI of the opening and closing of a valve, could please point it out to me.
Thank you in advance.
(3,513 Views)
Hi Russellg,
do you mean with "animation" more than two states? May be you only need a customized boolean control.
May be this helps
http://decibel.ni.com/content/docs/DOC-6325
Mike
(3,497 Views)
