annotate a graph - LV7.1
Hi all,
Is there a way to annotate a graph in LV7.1?  I just want to put labels on a graph to identify certain peaks.  Easy in LV8, but I can't figure out how to do it in 7.1.
Jim
Jim
LV 2020
Message 1 of 17
(5,200 Views)
I think you ve to use the Plot Name property.
BTW, how do you do this in LV 8?
Can you post some code ?
- Partha ( CLD until Oct 2027 🙂 )
Message 2 of 17
(5,194 Views)
Open the example finder and search for "programmatically annotate a graph".  I haven't actually used it yet, as my deployed systems are all LV7.1.
Jim
Jim
LV 2020
Message 3 of 17
(5,186 Views)
I didnt think that there was graph annotations in 7.1 I know there are graph annotations in 8.2+.  You can but a cursor at the peak X,Y and make the cursor transparent, show the cursor name where the name = the annote you wish (ie Peak A).  You can even tie this in to the peak find so your annotations  move with the graph.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 4 of 17
(5,184 Views)
You can fake this with cursors. If you create a cursor, you can set it's
text and position. If you hide the lines and cross, the text remains.
It it limited, but might be what you need. The number of cursors is limited
in 7.1, I thing 56 cursors or something.
Another option is to use the picture control graphs. It will be a lot of
work, but you can do anything you want with it.
Wiebe.
Message 5 of 17
(5,183 Views)
See the "Programmatically Annotate a Graph.vi" example. (Type annotation in
the example finder).
Wiebe.
Message 6 of 17
(5,183 Views)
Wiebe,
There is no such VI in LV 7.1. Smiley Sad
Or, am I missing something ?
Message 7 of 17
(5,178 Views)
Please see reply #10 in this thread where CC hacks the cursor list.
Ben
Message 8 of 17
(5,173 Views)
Partha,
I think you are correct.  I cannot find it in 7.1 either.
Jim
Jim
LV 2020
Message 9 of 17
(5,171 Views)
Thanks Weibe, while not as nice as the annotation feature in LV8, that will certainly get the job done.  Much appreciated.
Jim
Jim
LV 2020
Message 10 of 17
(5,167 Views)
