anritsu meter ml2488 scaling configuration
Hi All
is there a way to configure the scaling (ref level & scale) for the instrument in qustion?
the driver seems to lack the support for those configurations.
a revised driver is available?
Regards ofir
(3,009 Views)
One thing that you should do is first search the programming manual to see what are the necessary commands (if they exist). If you can find the commands, then you should be able to search the functions in the driver to see if they exist. They just might exist in a function that combines several operations. If they do not exist, then it should be a simple task to modify the driver by adding a new function. You can provide this as feedback to NI so that the driver can be updated.
(2,994 Views)
Hi ofir!
There are two ml 2488 drivers available on the Instrument Driver Network.  One for model A and one for model B. You can submit feedback directly to R&D by clicking the feedback button at the top right of the page.
Kristen H.
(2,974 Views)
