any advantage using TDM over text or csv file
I'm new to Labview with a lot of help from people here I've managed to make this VI which logs 34401 DMM measurements to a file. I noticed in the file IO functions there is Data Storage and was wondering...
1. if it can be used to store the data from the DMM?
2. Does the TDM store the data as the data is writen to it or does it only store the data once you close the file?
I'm asking the second question because my current vi, see attached, seems to only write the data once the file gets closed which has consequences if I plan to collect days or weeks of data
(5,424 Views)
