any examples of vi scripting an array??
Generic-GObject-Node-GrowableFunction-GrowableFunction
Message 11 of 13
(919 Views)
Generic >> GObject >> Node >> GrowableFunction.
You may need scripting enabled for these to be shown.  Go to Tools >> Options then VI Server page and enable scripting.
Also if you know the name of the class you can use quick drop.  Select the Object Class then use quick drop (CTRL + Space) then type GrowableFunction then press CTRL + B.
Message 12 of 13
(916 Views)
Thanks a lot guys ! It was disable in the option...
Bye
Message 13 of 13
(902 Views)
