any labview example for resonator parameter measurement?
Hellow!
I am doing the measurement of the resonator parameter(like C0,L,C1,R) using network analyzer, are there anybody has some experience about it, are there any example code? thanks a lot!
Mike
(2,445 Views)
Mike,
Which network analyzer are you using.  You may be able to find some LabVIEW drivers for it at the following link:
National Instruments Instrument Driver Network
You may also check the other thread you started and the responses from JL Chew.
Hope this helps!
Andy F.
(2,432 Views)
