append binary file
Hello!
I don't know if my problem is similar or not. I am using the example from the "event-driven circular hard disk data buffering" note. I have modified the software in order to add a detection of peak. If yes, this is my event and I will record the data just before and just after the event. After using this soft, I have a lot of data file. In another vi, I open all of this file and read the data. But even by opening only one file I get the error 4. What am I doing wrong?
thanks for your help!
sophie
PS: LV 8.2, I am acquiring the data in with the circbuffexample-main and I am reading the data with the multi file dialog-Soph. The scan rate is 300kHz. If you need more information don't hesitate to ask!
Message 11 of 11
(815 Views)
