append cursor (x,y) values to a file
I'm analyzing a simulated signal with various parameters using a power spectrum. As the internal peak finding function does not give satisfactory results, I'm finding the peaks by hand.
How do I write the coordinates of a cursor to a file? Ideally I want to open a table, append the current value of the cursor and two parameters into the next available row, and finalize the vi. Then change the parameters, run simulation and append the values to the row n+1. Is that possible?
Best,
Dmitry
(2,322 Views)
You can trigger an event case when the cursor is grabbed, released or moved.  The event case will return x and y cursor locaton values (DBL).
(2,315 Views)
