append table to report
When using MS Office Report express vi for inserting a test data table in a template and saving it as a word document everything goes well.
However, for using this as a functional global it is not the solution. So when using append table to report everything goes wrong.
I have several different sizes of tables which I have to append to the same document.  One with 7 columns, the next with two columns,etc. The tables overwrite each other and are making a mess with the document. I have set in the word template for table auto adapt to content.
This doesn't work. the column with the largest text makes two lines in each cell. Also the table with 2 columns shows as a 7-column table, a complete mess. How do I insert the tables in the document exactly as they show on the front panel.
(3,287 Views)
One idea might be to grab an image of the table and insert it into the report as an image.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,276 Views)
