append table with multi-line cells to word report
I am using LabView 7.0. I need to append table to word report and I am using Append Table to Report VI. My VI works fine as long as the table cells do not have multiple lines. For multiple lines, each line is put is a seperate cell in the word report.
Is there a way to append multi-line cells to Word Report??? If not, any suggestions on how I can copy the multi-line table to Word report???
Please kindly help!!
Please see the attached document for details on the problem.
Mim
Message 1 of 12
(3,934 Views)
Hi Mim,
With the use of the general 'append table' and the Word 'Easy table' I can insert tables with multiple lines.
I am using 7.1   Can you post a VI to see if it is reproducible on my PC
Message 2 of 12
(3,921 Views)
Hi KC,
I appreciate your time and help.
Please find attached my VI and the report template that the VI uses to create the report.
I look forward to your feedback.
Mim
Message 3 of 12
(3,916 Views)
Hi KC,
Just another note.. I can add table with multiple rows but if a cell has multi-lines, then it puts the next line in a different cell. I probably didn't mention this in my earlier note.
Thanks for your help,
Mimansa
Message 4 of 12
(3,912 Views)
Hi Mim,
Yes I understood the multiple-lines part. I think the doc is the report you want. Correct ?
The doc is generated with your VI without any modifications.
I am using XP, Office 2002 SP3 and LV7.1
Message 5 of 12
(3,908 Views)
Hi KC,
Thanks for your super prompt reply.
The VI adds tables, test information etc to the verification report template... so it does modify it.
I have Microsoft Office 2000 SR1-Professional and LV 7.0. This combination seems to be a problem.
Oh well.. I need to figure out how I can resolvethis issue. LV help does not specify which MS Office it is compatible with.. so I may be LV7.1 is required...
Thanks for your help...
Mims
Message 6 of 12
(3,901 Views)
A small language problem here I think.   'without modification' I refered to the VI not the doc file
Did you try the 'word easy tabel' VI ?
Message 7 of 12
(3,898 Views)
Hi KC,
OOps.. my bad!
Yes, I tried Word Easy vi.. that does the same thing.
Since, my generate report VI works fine on your setup.. I need to have LV7.1 may be?? Multiple line row works for excel so I am modifying my Vi to create excel report instead... I will let you know if that works.
Thanks...
mim
Message 8 of 12
(3,895 Views)
Hi KC,
Upgrading to LV7.1 resolved the problem. So, looks like LV 7.0 has a bug.
Thanks for your help in understanding the problem.
Mim
Message 9 of 12
(3,887 Views)
hi ,Mim
I download your zip, but I can not open a subvi 'Append Report Text (str).vi '
can you tell me why?
Message 10 of 12
(3,876 Views)
