appended array to spreadsheet
I have made a VI that obtains data from an oscilloscope with three different channels and output it to a graph. I also want to have it saved to a spreadsheet file with 4 columns: time, channel 1, channel 2, channel 3. I tried to convert these from array to string but it didnt work. I also tried to uncluster them but it didnt record the right time corresponding to the measurement. Does anyone know how to write this to a spreadsheet file as how it appears on the waveform graph?
 Thank you,
Max
(2,665 Views)
You need to convert your clusters to a waveform data type. A waveform type is a special type of cluster and the conversion is done with the Build Waveform function. You could also change the Fetch Waveform function to return a waveform instead of the cluster.
Message Edited by Dennis Knutson on 04-15-2009 03:48 PM
(2,652 Views)
