appending to an array of AXCont
In the attached VI, I would like to append two AXCont (two newly created globals not shown yet) to the array going into TestStand - Load Sizes.VI.  I'm trying to avoid modifying the existing clusters.  I was hoping to tap into the array after the conversion from cluster to array, and just add two more AXCont at the end.  Thoughts?
(2,579 Views)
Hello Mr. Bean,
Just use an Insert Into Array function to insert the two new globals after you have bundled them and converted them to an array.
Clint M
(2,552 Views)
