applicatie
What does TestStand with a LabView Modules and the vi's that are being used in these modules after making a UI in LabView and making an application of this UI with LV application builder. I'm going a bit mad because when I running the UI in Labview thers is no problem but after I make this UI an application TestStand give me Call's that I can't understand, For example 'can't find a parameter in the VI's connector pane'. This is all happening on one and te same computer so there are no changes in directories or whatever. I you have a clue please let me know.
Thanx,
Dennis
(2,702 Views)
TestStand VI's need to have certain controls (specific clusters) as input
and outputs. If the VI doesn't have those controls and indicators, TS
doesn't know what to do with it. I'd study the shipped examples.
Wiebe.
(2,679 Views)
