application build ask for file path
Hi there,
to build a application for cRIO start-up i've got an error from the builder. It asks me every time by build the path of a vi. But this SubVI's path is already known by the project.
How to remove the error?
Wilbur
PS: in the snapshot the right path of the vi has been indicated, but every time i have to select it manually using the "Browse..." button.
(3,970 Views)
(3,952 Views)
the problem is not during the execution, but by building the application in LabVIEW project.
The builder asks me the path of the vi, which he should already know.
As a EXE data, it works always well!
Thx
(3,946 Views)
Yeah, I haven't a clue why muks pointed you to that KB article either. As far as your problem is concerned, what do you mean by "this SubVI's path is already known by the project"? Is the VI actually in the project? Does the same thing happen when you open the VI on its own?
(3,939 Views)
Thx for ur suggestions!
The problem is that in the project this vi belongs to a library but some how it was kicked out and i have to save it again into the vi library.
So now it works!
(3,925 Views)
