application builder (activate activex)
Hello together,
you know that a VI can be compiled into an EXE-File with the Labview Application Builder.
Did somebody recognize the possibility to activate the ActiveX server within this EXE and made use of it?
(3,956 Views)
Nobody?
(3,942 Views)
STatzel
In version 7.1, select Tools>Build Application or Shared Library (DLL), then under the Application Settings tab click Enable Active X Server.
Under version 8.0, in the My Computer, Build Specification, under the Advanced tab click Enable Active X Server.
McSynth
(3,938 Views)
I ment:
Has somebody used it already? I like to control a any VI with the ActiveX Server and the Labview Online help is not helpful
(3,936 Views)
Here you can find general information concerning this topic.
https://www.ni.com/docs/en-US/bundle/labview/page/activating-labview-as-an-activex-server.html
There is an example shipping with LabView that shows how this works:
Refer to the VBToLV.frm, VBToLV.vbp, and VBToLV.vbw files in labview\examples\comm for an example of calling LabVIEW as an ActiveX server from Microsoft Visual Basic.
(3,918 Views)
