application builder error 26026
I got the error 26026 while making an application via application builder (LabView 7.1, Applicationbuilder 7.1, WinXP Prof. on Acer Travelmate Notebook).
The complete error description is: Fehler 26026 ist bei Build Application.vi >> Dist Call Create Installer.vi >> Win Install Create.vi >> MSI DK Set Properties.vi
 aufgetreten. Mögliche Gründe: NMDK_SP_BAD_DIRECTORY_PATH
There ist another thread with the error 26026, but on LabWindows/CVI http://forums.ni.com/ni/board/message?board.id=180&message.id=32044&query.id=99820#M32044
In this thread it is recommented to change some environment variables.
So I changed the %Temp% and %TMP% variable to c:\Temp and c:\TMP, but the error is still the same.
Are there some other advices for help?
Thanks for help!
(3,244 Views)
Hy Dominik,
I think you are on the right way and I also found the informations in your link. But moreover I found a Knowledge Base which could be intersting for you. I know that the error number is different to yours, but in other cases which were very similar to yours the problem could be solved.
http://digital.ni.com/public.nsf/allkb/6C0FB27EB0A1C0CE86256CDF007F6550?OpenDocument
Please try it and let me know if it works. Thanks for that.
Best wishes
Jan Kniewasser
Jan Kniewasser | Applications Engineer | Tel.: +49 89 7413130 | Fax: +49 89 7146035
(3,225 Views)
Hi Jan,
after Your reply I checked my installation directory names. And there I found my stupid mistake:
I want to have the standard installation sub directory LabView\ApplicationName. So the program menu is easier, because all my LabView-programs can be found under program - labview.
And I wrote labview/applicationname instead of labview\applicationname.
So if anyone has this failure please check that you use the backslash \ and not the slash / to separate sub-directories.
Thanks to Jan for this helpful link!
dominik
(3,219 Views)
