application builder error 7
Hello everybody!
I have a problem with the application builder...
Every time i try to creat a .exe file i get the same error message:
Error 7 occurred at Invoke Node in AB_EXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller
been trying some things but nothing worked!
Can someone help me?
(3,379 Views)
Do you "copy error files"?
If so, it is possible that you have no user right to overwrite the existing file......
Norbert
Norbert
Expert: Geometry
(3,370 Views)
I disabled it
Still the same...
Jo
(3,368 Views)
IT WORKED!!!
Just started LabVIEW in compatibility mode XP and its done...
i have no idea how that solved it... but as long as it's working i am ok with it Smiley Happy
(3,363 Views)
