application builder problem
I created a Vi that run the excel macro. It worked well but when I tried to build the exe file. It showed error1003 Possible vi is not executable.
Any ideas or comments?
(3,739 Views)
First, I suggest you upload the VI and tell us exactly when the error occures.
Second, is this happening on the same computer? If you are running on two computers with different versions of Office then you will have some incompatibilities which would require recompiling the VI.
Also, are you using any dynamic calls to VIs?
___________________
Try to take over the world!
(3,729 Views)
Like I indicated, my Vi had only one run macro property node and it worked ok. but I couldn't build it into an executable file.
(3,726 Views)
Do you use the 'Report generation toolkit'?
If so make sure the dynamic vi's are include (_excel.vi if I recall correctly)
Ton
My LabVIEW Ideas
(3,722 Views)
Here is a KnowledgeBase that tell you how to do this.
Chetan K
Application Engineering
(3,699 Views)
