application builder problem
I try to build the exe using application builder, and at the very end of the progress, it comes up with erro like below. Do you have any ideas?
 "Error 7 occurred at Libraian Get Info.vi-File not file
  Possible resons:
  LabView: file not found.
  or
  NI-488: Non-existent board"
(3,115 Views)
What version of LV?
What operating system?
Does this happen with any build or just this one?
Did this work at one time, but now is broken?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,112 Views)
I still use LV6.1
I don't have problem with other projects.
(3,109 Views)
Does this build include anything that you don't have in other applications that you have created - like new drivers or calls to external code like DLLs or ActiveX controls?
Mike...
LabVIEW Champion
(3,106 Views)
