application builder-run time error
I cannot run my exe file I have always the following message , see attachment.
What can be the problem?
(2,534 Views)
Is the run-time engine installed? A LV EXE can not run without the RTE.
When you build an EXE, you have the option to create an installer, which will also install the RTE. If you build an EXE with no VI defined, it should build an installer with only the RTE.
Alternatively, you can try looking for the RTE installer on your LV CD or on this site.
___________________
Try to take over the world!
(2,529 Views)
