application builder
Hai
In my PC application builder is not installing it shows some error. Cab files are missing. I tried with different CD. same thing happening. I formatted my PC and installed. still problem exists.
I investigate the internal error , it give a log file( attaching to this). And also some control palettes in the block diagram and front panel are not installed. print palettes execute control palette etc etc.
Content of lvfailurelog
#Date: Thu, Apr 01, 2010 12:59:25 PM
#OSName: Windows NT
#OSVers: 5.1
#AppName: LabVIEW
#Version: 7.1
#AppKind: FDS
D:\lvmerc\src\source\manager\image.cpp(2431) : DWarn: bad image in IRelease
$Id: //labview/branches/Mercury/dev/source/manager/image.cpp#8 $
0x0043825F - LabVIEW <unknown> + 0
0x009E64EE - LabVIEW <unknown> + 0
0x0082C84A - LabVIEW <unknown> + 0
0x0082BC95 - LabVIEW <unknown> + 0
0x009E3036 - LabVIEW <unknown> + 0
0x0067CA2F - LabVIEW <unknown> + 0
0x0061B527 - LabVIEW <unknown> + 0
0x0087C842 - LabVIEW <unknown> + 0
0x009E3859 - LabVIEW <unknown> + 0
0x0061AA40 - LabVIEW <unknown> + 0
0x0061A79C - LabVIEW <unknown> + 0
0x00570A67 - LabVIEW <unknown> + 0
0x0056E3C8 - LabVIEW <unknown> + 0
0x00567E6B - LabVIEW <unknown> + 0
0x005679CF - LabVIEW <unknown> + 0
"Thanks with regards "
by
..........Gireesh..........
(3,292 Views)
hi,
    I would suggest you to contact the Local NI support team to get the Installation files, as it is possible the installation files are corrupt on your CD.
Shreyas Hebbare
Shreyas Technologies
India
(3,251 Views)
I suspect a corruption.
Edit: Ok so most likely... :smileyvery-happy:
Message Edited by muks on 05-07-2010 12:43 PM
(3,249 Views)
