application crash report (user32.dll)
I have an actor based application. When i use "user32.dll - keybd_event" function, application gives the exception above. I used "keybd_event" function from the example that was downloaded the link below.
https://decibel.ni.com/content/docs/DOC-9001
I have attached the crash report for further information. Am I doing something wrong with "user32.dll" call or this is a bug?
(7,288 Views)
Accepted by topic author Zafer.Depe
Seems i solved the problem. I have made application of the original example and saw it also threw this exception. I was thinking about having a copy of "user32.dll" at data directory should cause a system error. After deleting the copy "user32.dll", application ran properly. But how I should prevent "application builder" to create a copy of "user32.dll" to data directory. I cannot see any settings about this inside build specifications.
(7,277 Views)
Step by step I solved the problem. I have checked "Specify path on diagram" and manually specified the path. This prevented additional "user32.dll" copies. If anyone meets "dll call" exceptions like that maybe this topic should be useful. By the way I am developing "OSK.exe" type virtual keyboard for LV applications. I will share the code after development and maybe people helps to improve it.
(7,261 Views)
Hi Zafer.Depe,
Thanks for following up with your solution!  It's posts like this that make the NI discussion forums such a great resource, and I'm sure someone will find your post useful.
(7,232 Views)
I duplicated this bug, but using user32.dll/FindWindowA.  Your approached fixed it for my case, too.  Thanks!  (More info below, if anyone is curious)
I didn't catch the bug till I worked on final deployment because I usually either ran from development mode, or copied just the .exe to another folder.  I think it worked at one time, though.
The original Windows\System32\user32.dll:  986kB, 11/10/2016 10:32AM
What I found in my data folder:  814kB, 11/10/2016 10:19AM
The wrong one, in Windows\SysWOW64\user32.dll:  814kB, 11/10/2016 10:19AM
It sure looks like LabView included the wrong user32.dll.  I found user32.dll in my dependencies list, but when I right-click/Explore..., it shows me the system32 copy.
I suspect something loaded the SysWOW64\user32.dll at some point, and after that, LabVIEW (32-bit) copied the wrong one over.
However, to make things especially confusing, I tried copying the System32\user32.dll into the data folder (without the fix above).  It didn't work.  I get "Missing external function user32.dll:FindWindowA:C in VI myvi.vi" (I did set calling convention to 'stdcall', not 'C', so I don't understand the :C).  I don't understand that one, but I guess I don't need to understand it since the fix above works (and better since it won't conflict with future Windows Updates).
Turns out, I didn't need the full .dll path.  This worked:
Shorter Version
___________________
CLD, CPI; User since rev 8.6.
(6,848 Views)
