application crashes when calling DLL built with LabVIEW 2011
Hello everybody,
Our application calls DLLs built with LabVIEW 2010 SP1. We installed LabVIEW 2011 and built some DLLs. So far so good. If we start our application and run 2010 DLLs it still works fine. If we run a 2011 DLL just once no error happens, but if we try to run the same 2011 DLL our application crashes reporting the error below. I saved the code for 2010 version and built a DLL and it works fine. Does anyone know why?
Thank you in advance.
#Date: Fr, 16. Sep 2011 16:25:25
#OSName: Microsoft Windows XP Service Pack 3
#OSVers: 5.1
#OSBuild: 2600
#AppName: PasTA
#Version: 11.0f2 32-bit
#AppKind: AppLib
#LabVIEW Base Address: 0x30000000
16.09.2011 16:25:26.181
Crash 0x0: Crash caught by NIER
File Unknown(0) : Crash: Crash caught by NIER
minidump id: 8a779b3f-51d7-4864-8e4d-6ab0195cd158
ExceptionCode: 0xC0000005
N
0x3072C804 - lvrt <unknown> + 0
0x3072CBB8 - lvrt <unknown> + 0
0x7C864191 - KERNEL32 <unknown> + 0
0x7C83AB50 - KERNEL32 <unknown> + 0
0x00000000 - PasTA <unknown> + 0
(3,148 Views)
Hi!
DLLs build with LabVIEW 2011 should not be run with LabVIEW 2010.
Either you build all DLLs in LV 2010, or you build them with LV 2011 but don't use them with LV 2010
(3,079 Views)
On that note, you should be able to create DLLs in 2010 and run them with 2011, correct??  In my case, I have a 2010 built DLL (talking to sbRIO), most of the functions work when run in 2011, but a couple of them lock up LabVIEW on the desktop (but not the sbRIO), no lock ups happen with 2010 on the desktop.
(3,051 Views)
