application has requested the runtime to terminate it in an unusal way
I had not run Labview 2011 on my laptop for several months.  Today, when I revisited a "read PNRF file" project, I discovered that I had to reinstalled the usiHBM_PNRF.msi.
Now, when I run the VI in the above picture, I get C++Runtime Library error (as shown), and LabVIEW immediately kills itself upon clicking [OK] in the error message.
I've narrowed the culprit down to the "Open Data Storage" VI.
Any thoughts are greatly appreciated.
(3,176 Views)
My first thought is to try to uninstall/reinstall the DataPlugin, as this sounds like a corrupted install problem. The DataPlugin installs some dlls created/distributed by HBM Perception that could have been created using Visual C++, hence the error message. Is there any programming software that has been added/removed since the last time you ran this project? Unfortunately the error message does not give us alot to go as far as what is causing the problem.
-Jake B.
(3,128 Views)
Hello Jake,
Yes, I removed and reinstalled the Dataplugin.  I think I'm going to have to uninstall then reinstall LabVIEW.
Ron
(3,117 Views)
