application help window
To All,
Is there a feature in labview to create an application help window?
-Cosmica
(3,205 Views)
Right click on a control and select description and tip.
Whatever you write in description will be displayed at the help window (ctrl+h) when the mouse is over that control.
(3,200 Views)
I wanted to do something like the LABVIEW help window with contents and index.
Thank you,
Cosmica
(3,197 Views)
Look on the Dialog & User Interface>Help palette.
(3,193 Views)
