application items in menu remains disable & Book about Labview
Good Morning,
I tried to add to my menu the following application items : Copy, Paste, Cut, Clear, but they remain disabled and I can't enable them. If someone have got an idea...
Concerning the programation of my application, I would like to have more advanced information, for exemple about how to use server, and I would like to have your suggestion about good books to buy.
Thanks in advance for your answer
Nicolas Minary
(3,121 Views)
For good books: anything by Gary Johnson. Get and read his books, they will answer all your other questions. Check Amazon.com, I believe they are still carrying them.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,121 Views)
As for the menu items, look at the following KnowledgeBase, particularly the example program that is linked at the bottom.
How Do I Create a Custom Run-Time Menu in LabVIEW?
http://digital.ni.com/public.nsf/websearch/17803AA31C8C07C986256CFD0080D609?OpenDocument
Let me know if you still have problems with the items being greyed out (disabled).
(3,121 Views)
Hello
Thanks first for your answer about my problems
I was not able to solve the problem with the capy and paste functions, which are always disabled. When i´m making a Ctrl+C or Ctrl+V when my program is runing, it is written C or V and all my selection is being cleared... no idea why this appeared...
thanks in advance for your help
Nicolas
(3,121 Views)
First of all, do you have copy, paste, etc. under the Edit menu and is Edit defined as Application Item for Item type? Second, are all of the sub-items also defined as Application Item? If all of this is correct, then can you attach a sample VI and the run-time menu that is causing you problems?
(3,121 Views)
Hello
I found the reason of my problem : the Edit menu was not defined as an Application Item, but as a user Item. So I deleted everything in my sub-menu, and added the whole Application Item; now it´s working fine. Thanks a lot for your helpful suggestion
Nicolas Minary
(3,121 Views)
