application of piano keyboard
i am thinking to make an application of piano keyboard... like using the system's keyboard keys to produce piano sounds... so how to produce sounds of given frequencies... are there any functions or api s for generating sounds of given frequencies...?
(3,080 Views)
If you have LV full or pro, you have the sound VIs, which allow sending a waveform to the speakers, and LV also has VIs for generating waveforms.
Also, if you search here for "piano" you can find at least a couple of implementations, such as these two:
http://forums.ni.com/t5/LabVIEW/VI-of-the-Day-9-4-2009/m-p/979091#M438671
http://forums.ni.com/t5/LabVIEW/piano/m-p/899357#M405706
___________________
Try to take over the world!
(3,070 Views)
