application title bar
All of my UI vi's have title bars not visible in development system. However, after I build the application all the title bars are visible. I don't want title bars visible. How do I fix this? Thanks in advance.
PaulG.
Retired
(3,366 Views)
rt click vi icon, goto vi properties, goto category, click window appearance, click customize, uncheck "window has title bar".
ooops!Smiley Surprised
(3,360 Views)
Check these settings
(3,346 Views)
Your image is hiding what I missed. Got it. I went through these screens 5 times. Honest! Smiley Happy
PaulG.
Retired
(3,336 Views)
It happens to the best of us...
(3,329 Views)
Actually this did NOT fix the problem. I select the Customize VI Properties and deselect "Window has title bar" but still get the title bars when I run the built app. When I go back to the builder and check "Window has title bar" it is selected. I can deselect it but it does not stay deselected. Smiley Indifferent
PaulG.
Retired
(3,315 Views)
As in the past VI properties selected from the menu do not carry over into an application. I had to work around by using VI Property > FP.TitleBarVis set to false. In. Each. And. Every. UI VI. Hey National Instruments: if something doesn't work then fix it or remove it.
PaulG.
Retired
(3,293 Views)
