application will not build because it cannot write the icon file to the application (Error 1 occurred at AB_Engine_EXE_Call_Write_Icons.vi -> AB_EXE.lvclass:Build.vi)
This error happens with the default icon and with custom icons.
(3,860 Views)
What is the path that you are building the application to?
(3,843 Views)
I just created a new project using the exact same settings and I was able to build.
Don't know what the problem was.
(3,761 Views)
