application windows maniplating
hi all i  made a application in labview .this contains three sub vis ie read write .when oan read event genrate  the read window open ,when write event genrate  write sub vi fornt panel is open.my question is after buid the aplication  when run application these three windows are present. in application when open and close the windows is thier any functions  to maniplate the windows
(2,798 Views)
File>VI Properties>Window Appearance
Christian
(2,790 Views)
You can use property nodes to manipulate windows programatically. You can show them, hide them, move them around and resize them. What exactly are you wanting to do?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,784 Views)
