applications using DAQmx VIs
Hi:
I am building an application in LabVIEW from a VI that uses DAQmx VIs.  On the production machine, I have installed DAQmx drivers and LabVIEW Runtime engine.  Now, when I try to run the application, it complains that it cannot load one of the DAQmx Read VIs which I have used in my application.  Is there any additional step that I need to perform when I am building application to overcome this problem.
thanks
---trupti
(3,374 Views)
Hi Trupti
as a start point check the following thread
http://forums.ni.com/ni/board/message?board.id=170&message.id=83866&requireLogin=False
or surf the discussion forum
chow
xseadog
(3,368 Views)
Hello Trupti,
If I understand your setup correctly, you are trying to distribute your application, which uses DAQ function calls, to another machine.  If this is the case and you are using LabVIEW 7.1 or prior versions, you need to seperately install DAQ on the other machine.
Hope that helps.
Wendy L
LabWindows/CVI Developer Newsletter
(3,349 Views)
  I am using Labview 7.0.  Looks like something messed up on my PC.  I also have 7.1 installed.  I accidentally open my vi's in 7.1 and then revert back to 7.0.  I am not sure but may be that messed it up.  I am saying this because,  I have an older copy on my laptop.  I made a build and that seems to work fine.  I have to look in to it more.
thanks
trupti
(3,338 Views)
