arbitrary axis labels on a bar graph
Is there a way to set my x-axis labels on a bar graph arbitrarily?  I found a 2-year-old thread that said you can't but I'm not sure if LV8 has added this ability.
What I need to do is have a 62-bar graph start at 0 and go to 60 by evens and right after 60 start at 1 and go by odds to 61.  Anyone have any ideas?
Lee Jay
(3,068 Views)
You might want to check out the thread that I started here
I asked essentially the same question and with a graph, the answer is no.  You will have to use a picture control, as shown in the thread.
Good luck
Kenny
Kenny
(3,067 Views)
Your question was a bit different.  I already have the bars themselves where I want them and I got them that way by manipulating the data.  You actually needed to move the data on the graph.  I need only to change the labels themselves.  I'm wondering if there's a way to make them strings instead of numbers or some such trick.
Lee Jay
(3,055 Views)
