arduino
Hi, Could someone please tell me if I have to write C code to an arduino to use a HC SR04 sensor and interface it with labview. If someone could explain how to interface this with just a VI I would be very grateful. I am new to all this and I have been assigned a project to measure distance with this sensor connected to an arduino and display the image on a HMI with labview. Any and all help appreciated
Carl
(2,858 Views)
Hi!
If you try to search the web you'll find some examples and sketches to interface Arduino with SR04 sketch.
For example: http://playground.arduino.cc/Code/SR04 (I've never tested it).
Once the sensor has been interfaced with the board it should be easy to implement with Labview a VISA a VI to read the measure from your PC.
Marco
(2,854 Views)
Post your question here
https://forums.ni.com/t5/LabVIEW-Interface-for-Arduino/ct-p/7008?view=discussions
Take a look at this link also
http://arduinobasics.blogspot.in/2012/11/arduinobasics-hc-sr04-ultrasonic-sensor.html'
http://www.instructables.com/id/Simple-Arduino-and-HC-SR04-Example/
Hopw this is what you are looking for
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,851 Views)
add other useful links, greetings
NI LabVIEW Interface for Arduino Toolkit -
http://sine.ni.com/nips/cds/view/p/nid/209835
Getting Started With the LabVIEW Interface for Arduino
http://vishots.com/getting-started-with-the-labview-interface-for-arduino/
(2,778 Views)
