arduion mega 2560 for thermocouple measurement
Hi
I am Labview beginner and I have this IV to get temp..how I can  replace DAQ Assistant with microcontroller  (arduion mega 2560) to get the temperatures
thanks:manhappy:
(3,011 Views)
Hey Othman,
This link here would be a good start for programming with the Arduino, our new toolkit would be how you can communicate with your device.  There should also be some helpful links and examples for you to look at.
https://decibel.ni.com/content/groups/labview-interface-for-arduino
Eric L.
Applications Engineering Specialist
(3,001 Views)
Thanks for the info.
I have this board I could not connecte it to Labview 8.2.
I did.:
1- install the arduino driver
2- i have it in COM 5
3. found an example(arduino connection  http://web.me.com/iklln6/automation/LabVIEW.html) in the internet I put VISA resource name baud rate
the board should give me 25 if it receive T
when I run it .>> there is no output
Thanks for all
thanks
(2,980 Views)
The Arduino for LabVIEW toolkit requires LabVIEW 2009 or later; sorry but your LabVIEW 8.2 won't work for it.
If you have any additional questions about the Arduino you need to post them in the Ardiuno for LabVIEW forums in the link below
https://decibel.ni.com/content/groups/labview-interface-for-arduino?view=discussions
Eric L.
(2,978 Views)
